[SOLVED] FreeRTOS aware in Segger Embedded Studio
    Well, after a bit more digger, it appears the OZone application is where Segger offers OS aware debugging. And it does a reasonable job, with FreeRTOS on the nRF52.
    NOTE: When I first got it going, it would get stuck attempting to run code under 0x0001000. It was exercised during the call to either vPortStartFirstTask or sd_softdevice_enable. Either way, after a lot of hunting I found that the solution was to replace to functions in the .jdebug file with:
    1. void AfterTargetReset (void)
    2. {
    3. unsigned int SP;
    4. unsigned int PC;
    5. SP = Target.ReadU32(0);
    6. Target.SetReg("SP", SP);
    7. PC = Target.ReadU32(4);
    8. Target.SetReg("PC", PC);
    9. }
    and
    1. void AfterTargetDownload (void)
    2. {
    3. unsigned int SP;
    4. unsigned int PC;
    9. }
    thomas
  • Hello Thomas,
    How to enable thread awareness in ES is explained here:
    wiki.segger.com/SEGGER_Embedde…ble_RTOS_thread_awareness
