Debug Does Not Stop at initial break point
    • Debug Does Not Stop at initial break point
      My code builds and downloads to the debugger (J-Link Ultra+). However, once it has loaded it seems to start running, and on a break is running in an unidentifiable area of code. This was previously working and I'm not aware of having made any changes. I have tried older, known working code and they exhibit the same behaviour.
      I'm using MacOS 10.14.3 and SES 4.16
      Where do i start debugging this?
      So you want to start debugging from the reset hanlder and not from main correct?
      In that case starte the debug session with F11 instead of F5. This will "step into" the application and you will halt at the absolute beginning of your application.
      Is that what you were looking for?
