2D graphics primitives
    • 2D graphics primitives
      Hi I have just started to get my feet wet with STemWin, bundled in STM32CubeMX. emWin version is 5.44+, running on an stm32f7 discovery board (STM32F756, and 480x272 LCD).
      Because maybe I'd like to use it professionally, once I have experience with it.
      Unfortunately, I run into some issues, and I have some questions.
      - When drawing these shapes: GUI_DrawRect, GUI_DrawRoundedRect, and GUI_DrawCircle, the PenSize is ignored, but other shapes use it. The size was reduced to 1 for these shapes.
      Is it expected behavior? Is there a way to set the pen size for above shapes?
      - AA variants seem top have the right PenSize, however using GUI_AA_DrawCircle, shows a circle where the outer edges are clipped off, see attached picture.
      Is there a way to get the shape drawn right?
      - GUI_DrawEllipse does not seem to have an 'AA' variant aka GUI_AA_DrawEllipse.
      Or is it there?
      STemWin version 5.44+ is the latest version available for ST platforms.
      Is it too old?
      Could I update it?
      My source is here:
      github.com/bkht/STemwin-on-stm32f7-dicovery
      Thank you very much for helping me out.
      The post was edited 12 times, last by Jack74044 ().
      Yes, this is the expected behavior. Unfortunately, it is not possible to set a pen size for these shapes. Instead of drawing a circle you can draw an arc which covers 360°, for this shape you can set a pen size. A simple rectangle can be drawn multiple times.
      Where does it get clipped? Do you draw it into a window or a memory device? If yes, enlarge the window or device. Of course you could also reduce the radius of the circle by the pen size.
      Or is it there?
      Unfortunately, there is no AA version of GUI_DrawArc().
      Is it too old?
      Could I update it?
      No it's not that old. The current version 5.48, so there were just to releases in between.
      It is up to ST to update the library.
      The only way for you to update to the latest version is to purchase a source code upgrade:
      segger.com/products/user-inter…win/emwin-source-upgrade/
      Jack74044:
      I'm not drawing the circle in a window, all shapes can be drawn using the entire LCD screen, the circle is just a small part on it, and get clipped as in the picture in the first post.
      If I reduce the radius by half the pen size, or even half the radius, the problem still exists, so it is definitely a bug in the circle drawing routine.
      It is nice we can use the ARC instead, and there is actually an AA version of that one too. Though is is my guess that the arc rendering may be slower than the circle rendering.
      Jack74044:
      emWin probably is a work in progress, may this be implemented in the future?
      Jack74044:
      I would wait for some improvements, like solving the circle clipping issue and a more consistent implementation of the pen size (for all basic shapes)...
      I will test a bit more, it may be interesting for my professional work, in the near future.
      The post was edited 3 times, last by Jack74044 ().
      There was a bug, we have fixed it with version 5.48a of emWin. Didn't remebered it...
      We always add new stuff or improve things. Yes, maybe we will add this is the future.
      EDIT:
      Under the following link you will find a project for Embedded Studio and the STM32F746 Discovery. It includes emWin V5.48o, you might want to give it a try. Beside of emWin it also includes a wide range of other middleware components like embOS, emUSB, emFile, etc..
      segger.com/downloads/eval/Segg…ry_CortexM_EmbeddedStudio
      To build and run the project you need two other things.
      Embedded Studio:
      segger.com/products/development-tools/embedded-studio/
      ST-Link Reflash utility which converts the ST-Link into a J-Link OB (don't worry you can restore the ST-Link):
      segger.com/downloads/jlink/STLinkReflash
