[SOLVED] SES 4.16 not showing RTT output
  • [SOLVED] SES 4.16 not showing RTT output
    After upgrading to 4.16, none of my projects output RTT text, except for a line feed. 4.12 works just fine if I reinstall it. I can also disable RTT output in the project options, run the command line JLinkRTTClient and that works.
    I've also made sure to update the SEGGER_RTT_*.c source files in the project to the latest from JLink 6.44d, which didn't make any difference.
    I'm running macOS 10.14.4 and using a Nordic nRF52840-DK. Any of the example projects in Nordic SDK 15.3.0 show the same behavior after modifying sdk_config.h to enable the NRF_LOG RTT backend.
    Any suggestions are appreciated, thank you!
    We tried to reproduce the issue but RTT data was showing up just fine in Embedded Studio 4.16.
    Attached you can find the example project used.
    Could you test your setup with that project. Is RTT output working as expected?
