Could not perform target reset failed to connect
    • Could not perform target reset failed to connect
      I am using Broadcomm "BCM89103". Core is Cortex-M7.
      When I try to flash, I use python script to flash the internal flash memory of 2MB.
      It throws me "Could not perform target reset failed to connect" error.
      Could you please tell me if you have any solution for this? Thanks.
      The BCM89103 seems to be a MIPS32 core and not Cortex-M7.
      Are you certain you mean the BCM89103?
