[SOLVED] Flasher ATE - reset target after programming
  • [SOLVED] Flasher ATE - reset target after programming
    We are using the Flasher ATE production programmer to program our boards in the factory.
    The Flasher ATE is used to program the internal flash of the Nordic NRF52x SoC.
    We have written a custom PC application that controls the Flasher ATE using several protocols:
    UDP, HTTP for discovery
    FTP for uploading firmware packages
    TELNET for command and control
    We are successful in programming, however we have some manufacturing tests that are supposed to run afterwards which require the firmware to be running on the target device (nrf52x). But the firmware does not run unless we power cycle the nrf52x. Is there a way to do a software reset using the Flasher ATE?
    From the Flasher ATE, we have only the SWD interface wires connected to the target board.
    Danny
  • Hello Danny,
    We received your inquiry in parallel through our Supportsystem.
    To avoid information being lost through multiple communication channels this thread will be closed now.
    Further communication will be done via the Supportsystem.
