[SOLVED] How do I force double to be single precision as I think I have hit a bug in the float library
  • [SOLVED] How do I force double to be single precision as I think I have hit a bug in the float library
    Hi
    I am porting an existing firmware build from Keil and also GCC where my code works. The code is for the Nordic nrf52840 which has 32bit floating point hardware
    I have code as follows which works when built using Keil or GCC v6.3.1
    char but[64];
    float val=-3.45e+11;
    sprintf(buf,"%.2f",val)
    However when built using Segger IDE 4.12 it does not.
    What happens is that it returns from sprintf() after about 12 seconds (as opposed instantaneously for Keil & GCC) and the value in buf has no relationship with the val.
    For example, I get
    Float Value= (-4294967295.\F567295)(-3.456000e+11)
    and not the (-3.456000e+11) is correctly printed where the format string is "%e"
    I will be most grateful for any feedback/insight to go beyond this
    Look forward to hearing from you and my gratitude in advance.
    Good to hear that you are up and running agian.
    As the initial inquiry has been solved this thread will be closed now.
