[SOLVED] TMS570 partial write
  • [SOLVED] TMS570 partial write
    I need to write several bytes in flash after Erase operation.
    If I write using JFlash or WriteMem command, instead it writes about 1024 bytes.
    This spoils ECC region.
    Is there any way to write, for instance, just 8 bytes and other part remain erased?
    CPU TMS570LS1114 and similar.
    Which memory area are you looking to write exactly?
    I conducted the following test with the latest J-Flash version and a TMS570LS target device:
    - erase Flash at 0x0
    - blank check
    - generate test data (4 words in my example)
    - write and verify
    - only 4 words written rest is 0xFF, see picture attached
    Does it work for you when you use the same steps?
