[SOLVED] Infineon XMC 2Go Debug failed , Using JLink V644b
  • [SOLVED] Infineon XMC 2Go Debug failed , Using JLink V644b
    Help me see what is wrong? Please
    I am using infineon XMC 2Go Evaluation Boards and DAVE-IDE-4.4.2-64Bit
    SEGGER JLink_Windows_V644b,
    Already viewed segger forum, test failed many times
    What am I doing wrong? Please help me.....
    From J-Link perspective the connect seems to have worked.
    For reference could you provide a screenshot of a J-Link Commander connect sequence?
    wiki.segger.com/J-Link_cannot_…ty_using_J-Link_Commander
    From the error message it appears that DAVE is using a wrong target device name. For this issue we recommend contacting Infineon support as it is not related to J-Link software.
  • Hi Nino, thank you for your reply.
    Please help me to check again.J-Link Commander connect sequence.
    If there is no problem with the J-LINK setting.
    I have to contact Infineon.
    Thank
    John
  • Hi John,
    Thank you for providing the connect sequence screenshot.
    From it we can see that from J-Link perspective everything is working correctly. What seems not to be working is DAVE telling J-Link the correct target device name.
    For this Infineon DAVE support is the correct contact.
