Register will not be shown after importing CUBEMX Project
    • Register will not be shown after importing CUBEMX Project
      I imported a CUBEMX project with Eclipse import. The porject works like it should. But when I do the debugging, only the CPU and VPF register are shown.
      What can I do, that all registers will be shown?
      To make target specific registers visible you have to set the target specific register definition file in your project settings.
      Otherwise only the basic Cortex registers will show that are available on all cores.
    • Hi Kai,
      If the project is running as expected then there is nothing to consider.
      But generally the following rules apply:
      wiki.segger.com/SEGGER_Embedde…to_SEGGER_Embedded_Studio
      The example is for EWARM->ES but the steps and troubleshooting are always the same.
