[SOLVED] Nordic SES and mbedTLS with Zephyr
  • [SOLVED] Nordic SES and mbedTLS with Zephyr
    HI,
    I am developing software in SES V4.14 Nordic version (downloaded using NRF connect) for Nordic NRF9160 DK and everything works great until I tried to add mbedTLS.
    Nordic sample uses Zephyr framework and works great , I tried to add mbedTLS by adding configuration to the .conf file and it give me error : error: #include expects "FILENAME" or <FILENAME>.
    It seems that SES don't find the correct file of config.h while there is config.h file...
    I asked in Zephyr slack and they said its an integration issue with CFG_FILE and SES , do you aware of it ? do you know when the fix will release ?
    David
  • Hello David,
    Zephyr and mbedTLS support is not provided by Segger. We recommend contacting Nordic in this regard.
    From the error message it seems that the macro MBEDTLS_CONFIG_FILE is not defined.
    You could try defining this manually or replace it with the actual file path.
