[SOLVED] How much RAM is required for J-Link to proper work with Flash breakpoints
  • [SOLVED] How much RAM is required for J-Link to proper work with Flash breakpoints
    i wasn't able to find anything in the manual about this. I want to replace the Ram area J-Link uses for Flash breakpoints (reprogramming the flash). I think the command for this is "SetWorkRam".
    I only found a Wiki-Page which says the amount of Ram should not be lower than 512 bytes. But what is the recommended size of RAM J-Link needs to work properly with Flash Breakpoints for CFI flashes ?
    Thanks for your help.
    Hans
  • Hi Hans,
    We received this inquiry via Supportsystem as well.
    To keep all information in one place this thread will be closed now.
    For everyone else, the minimum recommended RAM size is 5-6 kB.
