[SOLVED] jflash.exe executed from command line sometimes has error writing jflash.ini (Windows 10)
  • [SOLVED] jflash.exe executed from command line sometimes has error writing jflash.ini (Windows 10)
    When executing jflash.exe from the command line, sometimes it gives an error that it can't write jflash.ini. This error doesn't always occur. JFlash.exe is part of Segger J-link v631b running on Windows 10, and the command prompt is not run as administrator. I'm also using a J-link plus compact v10.1.
    Here's the command that is executed from within a project folder and not from the location of jflash.exe:
    "C:\Program Files (x86)\SEGGER\JLink_V631b\jflash.exe" -openprj".\pac55xx.jflash" -open".\Release\pac55xx_example_code.bin",0x0000 -auto -startapp
    The error is:
    - Error: Could not save file [C:\Program Files (x86)\SEGGER\JLink_V631b\JFlash.ini]
    The full output from the Jflash console is:
    Application log started
    - J-Flash V6.31b (J-Flash compiled Mar 2 2018 17:38:00)
    - JLinkARM.dll V6.31b (DLL compiled Mar 2 2018 17:37:53)
    Opening project file [.\pac55xx.jflash] ...
    Access is denied!
    - Project opened successfully
    The folder you are trying to write to is write protected by admin rights.
    Simply select another saving location for your project file and you should not see this error message anymore.
    Alternatively operate J-Flash with admin privileges if you really want to write into the installation folder.
