[SOLVED] Ozone loads elf file very slowly
  • [SOLVED] Ozone loads elf file very slowly
    Hi there,
    i had a similar problem with ozone a year ago and it seems to have come back. Our embedded software uses c++ quite alot. Also with templates etc. There the symbol table is quite huge and the elf file has around 40MB. When i load the .elf file in ozone, it hangs for about 5min until it loads the elf file.
    The error message looks like this:
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: DW_OP_GNU_convert.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0x0.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: DW_OP_GNU_const_type.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xFF.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: DW_OP_regval_type.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0x5.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0x4.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xF0.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: DW_OP_GNU_deref_type.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: DW_OP_convert.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xAB.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xAA.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xC6.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0x1.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xD1.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: DW_OP_constx.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xBD.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xB3.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0x7.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xDB.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: DW_OP_GNU_reinterpret.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xD0.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xCD.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xCC.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xD9.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xDE.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xAE.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xB7.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xC8.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: DW_OP_const_type.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xCA.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xB9.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xBE.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xD7.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xDA.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xBA.
    ELF warning (1009): the symbol location decoder encountered an unsupported operand: 0xF1.
    File.Open: completed in 272631 ms
    Edit.Preference (PREF_SHOW_ASM_CODE_PROFILE, 0);
    Edit.Preference (PREF_SHOW_SRC_CODE_PROFILE, 0);
    I currently use Ozone 2.60p in 64-Bit on Windows 10.
    Best,
    Hans
  • Hello Hans,
    We received your inquiry via our Supportsystem as well.
    To avoid double information this thread will be closed now.
    Just a quick info to other readers. We were able to improve the load time in this case to around 15 s.
    The improved version should be available with the next Ozone release V2.62.
