Programming value to flash、successed at the fifth time.
Application log started
- J-Flash V6.34f (J-Flash compiled Sep 5 2018 13:25:47)
- JLinkARM.dll V6.34f (DLL compiled Sep 5 2018 13:25:28)
Creating new project ...
- New project created successfully
Opening data file [C:\Users\STJ182460\Desktop\Project\FlashMap\flash.mot] ...
- Data file opened successfully (5360 bytes, 2 ranges, CRC of data = 0xB666B81D, CRC of file = 0x8117FC43)
Connecting ...
- Device "S32K142" selected.
- Target interface speed: 4000 kHz (Fixed)
- VTarget = 5.012V
- InitTarget()
- Found SW-DP with ID 0x2BA01477
- Scanning AP map to find all available APs
- AP[2]: Stopped AP scan as end of AP map has been reached
- AP[0]: AHB-AP (IDR: 0x24770011)
- AP[1]: JTAG-AP (IDR: 0x001C0000)
- Iterating through AP map to find AHB-AP to use
- AP[0]: Core found
- AP[0]: AHB-AP ROM base: 0xE00FF000
- CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
- Found Cortex-M4 r0p1, Little endian.
- FPUnit: 6 code (BP) slots and 2 literal slots
- CoreSight components:
- ROMTbl[0] @ E00FF000
- ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
- ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 003BB002 DWT
- ROMTbl[0][2]: E0002000, CID: B105E00D, PID: 002BB003 FPB
- ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
- ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
- Initializing 28672 bytes work RAM @ 0x1FFFC000
- Reset: Halt core after reset via DEMCR.VC_CORERESET.
- Reset: Reset device via AIRCR.SYSRESETREQ.
- Executing init sequence ...
- Initialized successfully
- J-Link found 1 JTAG device. Core ID: 0x2BA01477 (None)
- Connected successfully
Programming target (5360 bytes, 2 ranges) ...
- Checking if selected data fits into selected flash sectors.
- Start of preparing flash programming
- End of preparing flash programming
- Start of determining dirty areas in flash cache
- End of determining dirty areas
- CPU speed could not be measured.
- Start of flash programming
- Programming range 0x10000000 - 0x100017FF ( 3 Sectors, 6 KB)
- ERROR: Programming failed @ address 0x10000400 (block verification error)
- End of flash programming
- ERROR: Program failed
- ERROR: Failed to program target
Disconnecting ...
- Disconnected
- Connecting ...
- ERROR: Programming failed @ address 0x10000800 (block verification error)
Disconnecting ...
- Disconnected
- Connecting ...
- ERROR: Programming failed @ address 0x10000E00 (block verification error)
Disconnecting ...
- Disconnected
- Connecting ...
- Flash programming performed for 1 range (6144 bytes)
- 0x10000000 - 0x100017FF ( 3 Sectors, 6 KB)
- Start of restoring
- ERROR: Programming failed @ address 0x10001200 (block verification error)
- End of restoring
Disconnecting ...
- Disconnected
- Connecting ...
- End of restoring
- Target programmed successfully - Completed after 0.364 sec
Disconnecting ...
- Disconnected
Connecting ...
- VTarget = 5.012V
- InitTarget()
- AP[0]: Core found
Disconnecting ...
- Disconnected
- Connecting ...
Disconnecting ...
- Disconnected
- Connecting ...
Disconnecting ...
- Disconnected
- Connecting ...
- End of restoring
Disconnecting ...
- Disconnected
- Connecting ...
- End of restoring
Disconnecting ...
- Disconnected
