[SOLVED] jlink script: Commands to variable
  • [SOLVED] jlink script: Commands to variable
    From a jlink script, I would like to use data from a jlink command (mem32) and store its result into a variable. I'd like then use it for a wreg command. Is there any way to do it ?
    Thank you.
    You can call J-Link read and write calls directly from JLinkScript file so no command strings are needed.
    e.g.
    JLINK_MEM_ReadU32() or JLINK_MEM_WriteU32().
    How to use the wreg exec command in a JLinkScript is explained here:
    wiki.segger.com/Using_J-Link_Command_Strings
  • Thanks Nino for your fast answer.
    What i did have in mind was to use a .jlink file, I didn't know about .jlinkScript.
    I don't know if the .jlinkScript is a good approach as it seems to be used to customize existing functions.
    What I want to achieve is to load and run a binary located into RAM. I am able to do it manually with Jlink commander but I'd like to automate it a bit :
    Here is what I'd like to do in pseudo code:
    U32 SPvalue ;U32 PCvalue ;
    //Halt cpu
    h
    //Load binary
    loadbin C:\tmp\bin\MyBinary.bin, 0x20010000
    //Read Stack pointer addr
    SPvalue= JLINK_MEM_ReadU32(0x04000000);
    //Read ResetHandler addr
    PCvalue= JLINK_MEM_ReadU32(0x04000004);
    //Place stack pointer according to previous read
    wreg "R13 (SP)", SPvalue
    //Reset MSPLIM
    wreg MSPLIM, 0
    //Set program counter on ResetHandler Addr.
    setPC PCvalue
    // Launch program
    go
    What is the best way to do it ?
    Thank you.
    Thank you for clarifying your setup. In that case the commandfile (.jlink) is the right approach. However the scripting language here has no return values so no variables can be used.
    You would have to know them beforehand.
    Is a binary file the only output you got or do you also have the elf file output?
    In any way you could also use our universal debugger Ozone for your setup:
    segger.com/products/development-tools/ozone-j-link-debugger/
    It can be used for free with a J-Link Plus or higher and all debugger GUI actions are completely scriptable with several hook points that can be used.
