Correct configuration for STemWin drivers
    • Correct configuration for STemWin drivers
      I hope you can help with this. I am having trouble selecting the correct drivers and color conversion configuration. It seems no matter what combination I try, something is wrong.
      I am using the LTDC_PIXEL_FORMAT_ARGB8888 pixelFormat specifier on my layer config, and the driver library is the STemWin_CM4_OS_wc32_ot.a or STemWin_CM4_OS_wc32_ot_ARGB.a driver.
      The GUI_DRAW_BMPM8888I Bitmap was created with CVTBMP 5.44 using the True Color with Alpha, r/b swapped, alpha inverted option
      The GUI_DRAW_BMP8888 Bitmap was created with CVTBMP 5.44 using the True Color with Alpha option
      GUICC_M8888I and GUICC_8888 are COLOR_CONVERSION options.
      Matching GUICC_M8888I with ot_ARGB driver produces correct line drawing
      GUI_DRAW_BMPM8888I Bitmap has reversed R & B
      GUI_DRAW_BMP8888 Bitmap just shows white for colored areas
      Matching GUICC_M8888I with ot driver produces reversed R & B line drawing
      GUI_DRAW_BMPM8888I Bitmap is correct
      GUI_DRAW_BMP8888 Bitmap is correct
      Matching GUICC_8888 with ot driver produces correct line drawing
      Matching GUICC_8888 with ot_ARGB driver produces reversed R & B line drawing
      Lee
      The correct combination for the ST devices should be:
      GUICC_M8888I - In LCDConf.c
      GUI_DRAW_BMPM8888I - For the bitmap
      ARGB Library
      When using the ARGB Library make sure that the define GUI_USE_ARGB in GUIConf.h is set to 1. Otherwise the colors for line drawing is not correct.
    • Hi Sven,
      That did the trick, thanks! Although I found that at least in my setup there are two definitions of GUI_USE_ARGB - one in GuiConf.h and the other in GuiConfDefaults.h. I had already changed the one in GuiConfDefaults.h, but I guess I missed the one in GuiConf.h - or maybe it was the other way around. At any rate, I'm happy.
      Lee
      Better don't touch any other files than GUIConf.c, GUIConf.h, LCDConf.c and LCDConf.h.
      The file GUIConfDefaults.h is just to make sure that the defines have a value in case they are not defined in GUIConf.h. By setting defines in GUIConf.h it is possible to reconfigure emWin on build time. Of course, it is not possible to redefine these defines when using a pre-build library.
