[ABANDONED] Integrating Pc-Lint plus
  • [ABANDONED] Integrating Pc-Lint plus
    Ide version = 4.10 for ARM
    Various posts have attempted this, some claiming success with the following tools command :-
    "$(LINTDIR)\bin\pclp64.exe" -v -incvar(__CW_ARM) -i"$(LINTDIR)\lnt" "$(LINTDIR)\lnt\co-gcc.lnt" $(DEFINES) $(INCLUDES) -D__GNUC__
    -u -b +macros +macros -w2 -e537 +fie +ffn -width(0,4) -hF1 "-format=%f:%l:%C:\s%t:\s%m [-e%n]" "$(InputPath)"
    However, I cannot get the following built-in macros to work : $(DEFINES) $(INCLUDES)
    Has anybody had / solved this problem ? Does it matter if I use Debug/Release/Common configurations ?
    ( Whereas others such as $(InputFileName) work fine ! )
    ( PS : I haven’t really looked at the rest of the command line yet, until those macros work there is no point ! )
    Any suggestions ?
    An integration guide for external tools with Embedded Studio can be found in the Embedded Studio manual or in the manual online version:
    studio.segger.com/ide_external_tools_file_format.htm
  • Thanks for the reply, but I obviously read through all these notes before resorting to my initial post. My point is that the following built-in macros DO NOT WORK, they do not expand to anything when used on the command line :
    $(DEFINES)
    $(INCLUDES)
    Can you think of any reason why this would be the case ?
    The defines work just fine on my Win7 setup. Which OS are you running on?
    Could you show a screenshot of your global macro settings?
    Tools > Options > Building > Global Macros
    What values do you expect for $(DEFINES) or $(INCLUDES)? Could you provide your emProject file for reference?
    Out of the blue I am now getting somewhere. The in built macros have started to work, and PC-Lint is working, but I would like to achieve the following, all advice welcome :-
    I have added a PC_Lint utility as a tool, it lists the errors and warning in the output window, BUT it doesn't add them to the margin gutter in the source window.
    Can you tell me how I do this please ?
    Many thanks.
