[SOLVED] Register definition file causing issues
  • [SOLVED] Register definition file causing issues
    I am using embedded studio v4.12. After loading the LPC5410x.svd file, debugging slows down by factor of 1000 (maybe more). Each "step over" takes 2-3 minutes instead of 1second. This same file worked fine in version 3.42b, so I wouldnt say its corrupted definition file. I didnt noticed any issues on other mcu's I am using. That doesnt say much as I am only using 4 different mcu's, but still its not affecting performance on the others.
    Removing the "Register definition file" from debugger, returns everything to normal. Debugging is a breeze again without it, just the hot inferno breeze as I dont see any of the registers I change in the code :) :rolleyes:
    Anyone had similar experience ?
    Solution ?
    Could you provide us with the .svd file for reference?
    Does this issue happen only if certain peripherals are active or with all of them?`
    Bestr regards,
    Attached is the svd file. Issue happens as soon as I attach the svd file and do the first debugging over SWD. I dont even enable any of the peripherals in the register viewer.
    Didnt try JTAG, as I dont have compatible board. Removing the svd file, everything is back to normal.
    • LPC5410x.svd.zip
      (73.84 kB, downloaded 469 times, last: )
