SPINBOX used for set hour and minutes
    • SPINBOX used for set hour and minutes
      Hello to anyone,
      I'm quite new in emwin library, so I've a question.
      I thought to use spinbox for set hours and minute (12:00), I would not use (for graphical space) one spinbox for hours and one spinbox for minutes, I would use only one spinbox for sets hours and minutes , it is possible ?
      In alternative what I should use ?
      Thanks a lot for helping me.
      Marco P.
      The post was edited 2 times, last by marcopazzi ().
      Unfortunately, this is not possible with the SPINBOX.
      Try the example attached. I have set up a dialog which does what you want. You might want to adapt the look, but it should give you an idea on how to proceed.
      • SetTime.zip
        (1.47 kB, downloaded 206 times, last: )
