[SOLVED] GCC support missing in SEGGER_RTT_ASM_ARMv7M.s
  • [SOLVED] GCC support missing in SEGGER_RTT_ASM_ARMv7M.s
    Hi!
    I just downloaded the new SystemView 2.52f, and tried to compile it using a GCC toolchain.
    Apparently, the assembly file misses support for GCC.
    The easy fix is to just use the same settings for clang and GCC:
    1. #if defined (__SES_ARM) ---> #if defined (__SES_ARM) || defined(__GNUC__)
    Otherwise, a new constant #define _CCGCC 2 cand be introduced.
    best regards,
    Thomas
  • Hello Thomas,
    The issue is related to your other thread so this one will be closed:
    Recording stops with "Invalid packet received" when using assembly version
