[SOLVED] J-Trace and IAR
    IAR unfortunately does not support any streaming trace features.
    For the best trace experience we recommend using Ozone the J-Link debugger.
    It can be used for free with a J-Trace PRO and works with IAR output formats. So you can compile your application with your current IDE and debug it in Ozone with all J-Trace PRO features active.
    segger.com/products/development-tools/ozone-j-link-debugger/
    A List with Tested Devices for tracing can be found here:
    segger.com/products/debug-prob…echnology/tested-devices/
  • Hi Nino
    Thanks for your prompt response.
    Am I correct that the J-Trace has a 64 MB on-board trace buffer? If so, can one get IAR EWARM to work with that? The first J-Traces, without streaming trace, made use of a on-board buffer and it work quite well with EWARM. I know that I won't be using the great streaming capability, but at least I will be able to do some tracing with EWARM and my new J-Trace ;-).
    Gawie
  • Hello Gawie,
    Yes IAR will utilize the 64 MB on board buffer so depending of the target speed and created trace data this can be enough to reconstruct the last couple of seconds.
