Is it possible to rotate an Ellipse object?
    • Is it possible to rotate an Ellipse object?
      I want to rotate a FillEllipse. I test it with an Image and rotate it with Memory Device in simulation it work's but on target I haven't enough memory.
      Is it possible to rotate a drawn ellipse object, as the folowing code shows?
      GUI_SetColor(0xff);
      GUI_FillEllipse(100, 180, 50, 70);
      Unfortunately, this is not possible.
      EDIT: Actually it is..
      The only way I could image is to use memory devices. Sorry.
      Maybe you can define the ellipse as a polygon (of course, this would require some memors for the points) and then use the function GUI_RotatePolygon().
      Like this:
      1. #include "DIALOG.h"
      3. *
      4. * Externals
      5. *
      7. */
      9. *
      10. * Defines
      11. *
      12. **********************************************************************
      13. */
      14. #define X_RADIUS 50
      15. #define Y_RADIUS 70
      16. /*********************************************************************
      17. *
      18. * Static data
      19. *
      20. **********************************************************************
      21. */
      22. static GUI_POINT _aPoints[1000];
      23. static GUI_POINT _aPointsWork[1000];
      24. /*********************************************************************
      25. *
      26. * Static code
      27. *
      28. **********************************************************************
      29. */
      30. /*********************************************************************
      31. *
      32. * _cbBk
      33. */
      34. static void _cbBk(WM_MESSAGE * pMsg) {
      35. switch (pMsg->MsgId) {
      36. case WM_PAINT:
      37. GUI_SetBkColor(GUI_BLACK);
      38. GUI_Clear();
      39. break;
      40. default:
      41. WM_DefaultProc(pMsg);
      42. break;
      43. }
      44. }
      45. /*********************************************************************
      46. *
      47. * Public code
      48. *
      49. **********************************************************************
      50. */
      51. /*********************************************************************
      52. *
      53. * MainTask
      54. */
      55. void MainTask(void) {
      56. int x;
      57. int y;
      58. int NumPoints;
      59. GUI_Init();
      60. GUI_Clear();
      61. //
      62. // Create polygon
      63. //
      64. NumPoints = 0;
      65. GUI_DrawEllipse(X_RADIUS + 1, Y_RADIUS, X_RADIUS, Y_RADIUS);
      66. for (y = 0; y < Y_RADIUS + 1; y++) {
      67. for (x = X_RADIUS; x < X_RADIUS * 2 + 1; x++) {
      68. if (GUI_GetPixelIndex(x, y) == 0xFFFFFFFF) {
      69. _aPoints[NumPoints].x = x;
      70. _aPoints[NumPoints].y = y;
      71. NumPoints++;
      72. }
      73. }
      74. }
      75. for (y = Y_RADIUS; y < Y_RADIUS * 2 + 1; y++) {
      76. for (x = X_RADIUS * 2 + 1; x > X_RADIUS; x--) {
      77. if (GUI_GetPixelIndex(x, y) == 0xFFFFFFFF) {
      78. _aPoints[NumPoints].x = x;
      79. _aPoints[NumPoints].y = y;
      80. NumPoints++;
      81. }
      82. }
      83. }
      84. for (y = Y_RADIUS * 2 + 1; y > Y_RADIUS; y--) {
      85. for (x = X_RADIUS; x > 0; x--) {
      86. if (GUI_GetPixelIndex(x, y) == 0xFFFFFFFF) {
      87. _aPoints[NumPoints].x = x;
      88. _aPoints[NumPoints].y = y;
      89. NumPoints++;
      90. }
      91. }
      92. }
      93. for (y = Y_RADIUS; y > 0; y--) {
      94. for (x = 0; x < X_RADIUS; x++) {
      95. if (GUI_GetPixelIndex(x, y) == 0xFFFFFFFF) {
      96. _aPoints[NumPoints].x = x;
      97. _aPoints[NumPoints].y = y;
      98. NumPoints++;
      99. }
      100. }
      101. }
      102. GUI_Clear();
      103. GUI_RotatePolygon(_aPointsWork, _aPoints, NumPoints, 45.0f);
      104. GUI_DrawPolygon(_aPointsWork, NumPoints, 100, 100);
      105. while (1) {
      106. GUI_Delay(100);
      107. }
      108. }
      109. /*************************** End of file ****************************/
