J-Link support for ZGM130S037HGN
    • J-Link support for ZGM130S037HGN
      New
      We are planing on using the ZGM130S037HGN from silabs. Would like to use the J-Link programmer to program the chip. I understand support might be included in the next Beta Release. When is support for the ZGM130S037HGN scheduled for? How can I get access to Beta release if it supports ZGM130S037HGN?
      CFV
    • New
      We can't find any information about the ZGM130S037HGN. Could you provide a reference link?
      What Coretype is it?
      Currently supported devices can be found here:
      segger.com/products/debug-prob…pported-cpus-and-devices/
      Should your Core type be listed you can also add support yourself:
      wiki.segger.com/Adding_Support_for_New_Devices
    • New
      Hi Nino,
      Thank you for your prompt reply. The ZGM130S037HGN is a Silicon Labs chip (like the EFM8) Segger also supports the EFR32FG13PxxxF512 from Silicon Labs. The core is an M4.
      I'll try the instructions that you provided for "Using a Precompiled Flashloader". Also I forgot to mention that I'm using the Linux ARM version of J-Link.
      I'll let you know if that works.
      CFV
      I tried the instructions:
      1. Open JLinkDevices.xml in a text editor and add the device entry at the beginning, right after the <Database> opening tag.
        Example:
        <!-- This entry will overwrite the existing device entry in the J-Link software, so that a custom flash algorithm is used for the internal flash --> <ChipInfo Vendor="ST" Name="STM32F767ZI" Core="JLINK_CORE_CORTEX_M7" /> <FlashBankInfo Name="Internes Flash" BaseAddr="0x08000000" MaxSize="0x00200000 " Loader="ST_STM32F7xxxx_2MB_DualBank.elf" LoaderType="FLASH_ALGO_TYPE_OPEN" /> </Device>
      2. Copy the flashloader file, referenced in the JLinkDevices.xml entry, into the same directory where also the JLinkDevices.xml is located (in this example ST_STM32F7xxxx_2MB_DualBank.elf).
      The problem is that I don't have an .elf loader file. Where would I get the appropriate file for my device?
      The post was edited 2 times, last by cvicens ().
    • New
      You need to write your own. How is explained here:
      wiki.segger.com/Adding_Support…ng_SEGGER_Embedded_Studio
      There is no precompiled flash loader for this device yet as the target device is unknown to us.
