Ozone issue with ADS generated axf image
    • Ozone issue with ADS generated axf image
      Dear all,
      I have an old project that I need to maintain. This project is still using ADS 1.2 compiler.
      I would like to use Ozone to debug this project, I have tried to open the .axf image in Ozone. It open correctly and can see all function listed but the link with source file is wrong.
      According to Ozone all the function are from .h files and not .c. The filename is correct (expected the extension and the line number is correct).
      Any idea why Ozone see the wrong file ?
      PGE
      This sounds like an incompatibility of the elf file with current standards. Could you provide us with the elf file so we could check if there is a generic issue with Ozone interpreter?
