embOS message 166 OS_ERR_CPU_STATE_ISR_ILLEGAL
  • embOS message 166 OS_ERR_CPU_STATE_ISR_ILLEGAL
    Hi All,
    I am getting error message 166 OS_ERR_CPU_STATE_ISR_ILLEGAL, while trying to do reset. I am using LM3S9B90 cpu.
    Once runing the program and the OS is ok , if i then do a hardware or software reset of the device my program does not start due to this error 166 OS_ERR_CPU_STATE_ISR_ILLEGAL.
    To summarize:
    So after flashing it works but after some kind of reset(software/hardware) the OS does not start due to this error.
    P.S. : I also got error 164 OS_ERR_IN_ISR
    Any ideas?
    The post was edited 1 time, last by tmanev ().
    which embOS do you use? Do you use one of our start projects or your own project?
    Do you use a debugger so that your able to step through the code? It would be interesting to see where OS_Error() is called.
    Kind regards,
    Til
