VTarget = 0.0V but JTAG pin 1 = 3.3V
    • VTarget = 0.0V but JTAG pin 1 = 3.3V
      My J-Link EDU is unable to connect with my target processor (an ATSAME54P20). Here's what J-Link Commander reports upon startup:
      1. SEGGER J-Link Commander V6.41a (Compiled Nov 27 2018 14:10:26)
      2. DLL version V6.41a, compiled Nov 27 2018 14:09:51
      3. Connecting to J-Link via USB...O.K.
      4. Firmware: J-Link V9 compiled Oct 25 2018 11:46:07
      5. Hardware version: V9.40
      6. S/N: 269402808
      7. License(s): FlashBP, GDB
      8. OEM: SEGGER-EDU
      9. VTref=0.000V
      10. Type "connect" to establish a target connection, '?' for help
      11. J-Link>
      The suspicious part is "VTref=0.000V". But when I measure the voltage on pin 1 of the 20 pin JTAG connector, I see 3.3V. Does this indicate a faulty J-Link? Or are there other things that could cause this?
      Such an issue is not known to us. If you measure 3.3 V on Pin 1 J-Link should see it too.
      Are you using the original JTAG cable shipped with J-Link? If yes, do you have another cable to test against?
      Just to be sure could you double check for correct cable orientation?
      segger.com/products/debug-prob…gy/interface-description/
      Should VTref keep showing 0 V no matter what JTAG cable is used it is most likely defective.
      As the references J-Link is out of maintenance for quite a while now we suggest making use of our trade in program:
      segger.com/purchase/trade-in-program/
