cannot execute this command without a live selected thread
    • cannot execute this command without a live selected thread
      Hi - I'm developing on a STM Nucleo-F413ZH Nucleo-144 Discovery board using STM/Atollic Eclipse. Because Segger doesn't provide a cable to connect my JLink to the debug header STM puts on these boards (please make and sell these!), I'm using the Segger-provided software in the onboard debugger. On this board (but not other boards I use), when I start the debugger it fails in the startup script, and pauses the debugger someplace related to the previous run. How can I get debug launch to work properly?
      Thanks!
      Best Regards, Dave
      [img]https://community.st.com/sfc/servlet.shepherd/version/renditionDownload?rendition=THUMB720BY480&versionId=0680X000006I912&operationContext=CHATTER&contentId=05T0X00000OPfzb&page=0[/img]
    • Hello Dave,
      For reference we tried to reproduce the issues with the same board.
      Attached you can find a successful connect session with J-Link Commander and a reference project for Embedded Studio and Ozone that runs out-of-the-box.
      Could you provide the Commander output of a connect session?
      Does the reference project work on your target hardware using Embedded Studio or Ozone?
      The demand is simply to low as SWD is connected on Nucleo boards on the arduino headers which can be connected to J-Link via jumper wires.
    • Apologies Nino if I wasn't clear. Connection is AOK, but the error happens on starting debug.
      I've attached console output below in case that's helpful.
      Thanks again for the help,
      Best Regards, Dave
      1. SEGGER J-Link GDB Server V6.34e Command Line Version
      2. JLinkARM.dll V6.34e (DLL compiled Aug 30 2018 17:36:45)
      3. Command line: -port 2331 -s -CPU Cortex-M -device STM32F413ZH -endian little -speed 3200 -if swd -vd -rtos C:\Program Files (x86)\Atollic\TrueSTUDIO for STM32 9.1.0\Servers\J-Link_gdbserver\GDBServer\RTOSPlugin_FreeRTOS.dll -swoport 2332
      4. -----GDB Server start settings-----
      5. GDBInit file: none
      6. GDB Server Listening port: 2331
      7. SWO raw output listening port: 2332
      8. Terminal I/O port: 2333
      9. Accept remote connection: localhost only
      10. Generate logfile: off
      11. Verify download: on
      12. Init regs on start: off
      13. Silent mode: off
      14. Single run mode: on
      15. Target connection timeout: 0 ms
      16. ------J-Link related settings------
      17. J-Link Host interface: USB
      18. J-Link script: none
      19. J-Link settings file: none
      20. ------Target related settings------
      21. Target device: STM32F413ZH
      22. Target interface: SWD
      23. Target interface speed: 3200kHz
      24. Target endian: little
      25. Connecting to J-Link...
      26. J-Link is connected.
      27. Firmware: J-Link STLink V21 compiled Jun 26 2017 10:35:16
      28. Hardware: V1.00
      29. S/N: 778227718
      30. Checking target voltage...
      31. Target voltage: 3.30 V
      32. Listening on TCP/IP port 2331
      33. Connecting to target...Connected to target
      34. Waiting for GDB connection...Connected to 127.0.0.1
      35. Reading all registers
      36. Read 4 bytes @ address 0x08003080 (Data = 0xD9FB2B01)
      37. Read 4 bytes @ address 0x08002B60 (Data = 0x681B4B0B)
      38. Loading RTOS plugin: C:\Program Files (x86)\Atollic\TrueSTUDIO for STM32 9.1.0\Servers\J-Link_gdbserver\GDBServer\RTOSPlugin_FreeRTOS.dll...
      39. RTOS plugin (API v1.0) loaded successfully
      40. RTOS plugin initialized successfully.
      41. Received symbol: pxCurrentTCB (0x20003C54)
      42. Received symbol: pxReadyTasksLists (0x20003C60)
      43. Received symbol: xDelayedTaskList1 (0x20003D00)
      44. Received symbol: xDelayedTaskList2 (0x20003D14)
      45. Received symbol: pxDelayedTaskList (0x20003C58)
      46. Received symbol: pxOverflowDelayedTaskList (0x20003C5C)
      47. Received symbol: xPendingReadyList (0x20003D34)
      48. Received symbol: xTasksWaitingTermination (0x00000000)
      49. Received symbol: xSuspendedTaskList (0x20003D4C)
      50. Received symbol: uxCurrentNumberOfTasks (0x20003CEC)
      51. Received symbol: uxTopUsedPriority (0x00000000)
      52. Received symbol: uxTopReadyPriority (0x20003CFC)
      53. Received symbol: vPortEnableVFP (0x08002BB4)
      54. Received symbol: FreeRTOSDebugConfig (0x00000000)
      55. All mandatory symbols successfully loaded.
      56. Connected to 127.0.0.1
      57. Reading all registers
      58. Read 4 bytes @ address 0x08003080 (Data = 0xD9FB2B01)
      59. Read 4 bytes @ address 0x08002B60 (Data = 0x681B4B0B)
      60. Received symbol: pxCurrentTCB (0x20003C54)
      61. Received symbol: pxReadyTasksLists (0x20003C60)
      62. Received symbol: xDelayedTaskList1 (0x20003D00)
      63. Received symbol: xDelayedTaskList2 (0x20003D14)
      64. Received symbol: pxDelayedTaskList (0x20003C58)
      65. Received symbol: pxOverflowDelayedTaskList (0x20003C5C)
      66. Received symbol: xPendingReadyList (0x20003D34)
      67. Received symbol: xTasksWaitingTermination (0x00000000)
      68. Received symbol: xSuspendedTaskList (0x20003D4C)
      69. Received symbol: uxCurrentNumberOfTasks (0x20003CEC)
      70. Received symbol: uxTopUsedPriority (0x00000000)
      71. Received symbol: uxTopReadyPriority (0x20003CFC)
      72. Received symbol: vPortEnableVFP (0x08002BB4)
      73. Received symbol: FreeRTOSDebugConfig (0x00000000)
      74. All mandatory symbols successfully loaded.
      75. Received monitor command: WriteDP 0x2 0x000000F0
      76. O.K.
      77. Received monitor command: ReadAP 0x2
      78. O.K.:0xE00FF003
      79. Reading 32 bytes @ address 0xE00FFFD0
      80. Reading all registers
      81. Read 2 bytes @ address 0x08003E44 (Data = 0xB508)
      82. Received monitor command: speed 30
      83. Target interface speed set to 30 kHz
      84. Received monitor command: endian little
      85. Target endianess set to "little endian"
      86. Received monitor command: reset
      87. Resetting target
      88. Received monitor command: speed auto
      89. Select auto target interface speed (2000 kHz)
      90. Received monitor command: flash download = 1
      91. Flash download enabled
      92. Downloading 472 bytes @ address 0x08000000 - Verified OK
      93. Downloading 992 bytes @ address 0x080001E0 - Verified OK
      94. Downloading 976 bytes @ address 0x080005C0 - Verified OK
      95. Downloading 976 bytes @ address 0x08000990 - Verified OK
      96. Downloading 992 bytes @ address 0x08000D60 - Verified OK
      97. Downloading 960 bytes @ address 0x08001140 - Verified OK
      98. Downloading 992 bytes @ address 0x08001500 - Verified OK
      99. Downloading 992 bytes @ address 0x080018E0 - Verified OK
      100. Downloading 992 bytes @ address 0x08001CC0 - Verified OK
      101. Downloading 960 bytes @ address 0x080020A0 - Verified OK
      102. Downloading 976 bytes @ address 0x08002460 - Verified OK
      103. Downloading 976 bytes @ address 0x08002830 - Verified OK
      104. Downloading 992 bytes @ address 0x08002C00 - Verified OK
      105. Downloading 992 bytes @ address 0x08002FE0 - Verified OK
      106. Downloading 976 bytes @ address 0x080033C0 - Verified OK
      107. Downloading 976 bytes @ address 0x08003790 - Verified OK
      108. Downloading 976 bytes @ address 0x08003B60 - Verified OK
      109. Downloading 976 bytes @ address 0x08003F30 - Verified OK
      110. Downloading 960 bytes @ address 0x08004300 - Verified OK
      111. Downloading 404 bytes @ address 0x080046C0 - Verified OK
      112. Downloading 592 bytes @ address 0x08004854 - Verified OK
      113. Downloading 8 bytes @ address 0x08004AA4 - Verified OK
      114. Downloading 4 bytes @ address 0x08004AAC - Verified OK
      115. Downloading 4 bytes @ address 0x08004AB0 - Verified OK
      116. Downloading 24 bytes @ address 0x08004AB4 - Verified OK
      117. Writing register (PC = 0x 8004790)
      118. Read 2 bytes @ address 0x08003E44 (Data = 0xB508)
      119. Received monitor command: reset
      120. Resetting target
      121. Read 2 bytes @ address 0x08003E44 (Data = 0xB508)
      122. Received monitor command: sleep 500 # Erich's suggestion - Does not help...
      123. Sleep 500ms
      124. Read 4 bytes @ address 0x08003080 (Data = 0xD9FB2B01)
      125. Read 4 bytes @ address 0x08002B60 (Data = 0x681B4B0B)
      126. Read 4 bytes @ address 0x08003080 (Data = 0xD9FB2B01)
      127. Read 4 bytes @ address 0x08002B60 (Data = 0x681B4B0B)
      128. Read 4 bytes @ address 0x08003080 (Data = 0xD9FB2B01)
      129. Read 4 bytes @ address 0x08002B60 (Data = 0x681B4B0B)
      130. Read 4 bytes @ address 0x08002B60 (Data = 0x681B4B0B)
      131. Read 4 bytes @ address 0x20004888 (Data = 0x0000F011)
