Custom bitmap drawing for rotated driver not called
    • Custom bitmap drawing for rotated driver not called
      Hi there,
      When using LIN_OSY_16 rotated driver it seems that custom 1bpp bitmap drawing routine is not being used. Instead "default" _DrawBitmap/_DrawBitLine1BPP_Swap get called.
      I've got GUI_SUPPORT_ROTATION set to 1, but GUI_pLCD_APIList pointer remains set to 0.
      What's the best/proper way to set custom drawing functions for rotated drivers?
      Many thanks!
      the functions for drawing bitmaps with the hardware acceleration are getting set only with the default rotation. As far as I know this is a limitation of the Chrome-Art-Accelerator.
      If you have enough RAM you can use the function GUI_SetOrientation(). Call the function after GUI_Init() (or before you start drawing anything). This function creates a kind of memory device which gets rotated. In combination with the default orientation (use GUIDRV_LIN_16 instead of GUIDRV_LIN_OSY_16) the drawing of the memory device should get performed with the hardware acceleration, which is quite fast.
