[SOLVED] S32K can not connect after program
  • [SOLVED] S32K can not connect after program
    Accidentally I flashed garbage data on my S32K148 CPU. It seem that CPU is constantly rebooting (looking at RESET_PIN behavior).
    It looks like CPU is not halting (the same symptoms as in Cannot connect to board after erase!).
    I am not able to connect with debugger, or unlock/erase this part. Reading MDM-AP Status register returns 0x34.
    It means that flash is locked and mass erase is allowed so in theory I should be able to unlock and do mass erase of this particular chip. However flash is in not ready state.
    As I understand JTAG commands can be accepted only when reset PIN is in high state. In my case this is very short window.
    My idea is to blindly send halt command over JTAG for this CPU after power up and release from reset using r1 command from J-Link script.
    I would like to as how the reset command (or commands) over JTAG should looks like for this cpu? I thing wjc or wjraw command can be fast enough?
    EDIT:
    It looks like in the data I flashed my reset pin is disabled, so the problem is quite generic for those parts - there is very short window to halt CPU.
    Do you have some ideas how can I test it?
    See logs:
    SEGGER J-Link Commander V6.40 (Compiled Oct 26 2018 15:06:29)
    DLL version V6.40, compiled Oct 26 2018 15:06:02
    Firmware: J-Link Lite-FSL V1 compiled Jun 25 2012 16:40:07
    Hardware version: V1.00
    S/N: 430110131
    VTref=3.503V
    J-Link>connect
    Please specify device / core. <Default>: S32K148
    Type '?' for selection dialog
    Device>
    J) JTAG (Default)
    S) SWD
    T) cJTAG
    TIF>j
    Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
    JTAGConf>
    Speed>
    Device "S32K148" selected.
    Connecting to target via JTAG
    InitTarget()
    TotalIRLen = 4, IRPrint = 0x01
    JTAG chain detection found 1 devices:
    #0 Id: 0x0995001D, IRLen: 04, JTAG-DP
    Protection bytes in flash at addr. 0x400 - 0x40F indicate that readout protection is set.
    For debugger connection the device needs to be unsecured.
    Note: Unsecuring will trigger a mass erase of the internal flash.
    Executing default behavior previously saved in the registry.
    Device was not unsecured. No action performed.
    AP[2]: Stopped AP scan as end of AP map has been reached
    AP[1]: JTAG-AP (IDR: 0x001C0000)
    AP[0]: Skipped. Invalid implementer code read from CPUIDVal[31:24] = 0x00
    AP[1]: Skipped. Not an AHB-AP
    InitTarget()
    ****** Error: Could not find core in Coresight setup
    InitTarget()
    InitTarget()
    Cannot connect to target.
    The post was edited 2 times, last by krzemyk: New informations. ().
    For mass erase to work the reset pin must be connected and controllable by J-Link. If your application remaps the reset pin J-Link can no longer reset the device via that pin.
    In theory you could try to hit that time window after restart but chances are slim that you are fast enough. To test the sequence we recommend using a JLinkScript to even have the chance to be fast enough.
    More information about JLinkScript files can be found in the J-Link user manual UM08001. There you can esentially replace the default connect and reset logic and implement your own.
    Please understand that we can't offer support such a specific setup.
