Clang compilation database
    • Clang compilation database
      We're trying to get the -MJ compilation database option to work when using clang as the compiler. I've tried a few variations but always get error: unknown argument. I've also tried wrapping with the -Xclang option but no luck.
      The incantation looks like this
      $SEGGER_PATH/llvm/bin/clang -cc1 [options] [file] -MJ file.o.json
      Has anyone been able to make this work? I'm wondering what the cc1 option does since it does not appear in the --help menu.
      In ES the clang driver isn't used, the compiler is called directly.
      What exactly is the setup you are trying to achieve here with CL option -MJ?
      Thank you for clarification.
      For easier project management external toolchains can also be called from within Embedded Studio:
      wiki.segger.com/SEGGER_Embedde…hain_with_Embedded_Studio
      Maybe that helps?
