[SOLVED] Getting Started with Flasher ATE on STM8 Devices
  • [SOLVED] Getting Started with Flasher ATE on STM8 Devices
    Hello all,
    I'm working on a project involving the Flasher ATE for a production flasher. I have been reading through the documentation (UM08035) to figure out how this thing works but I am having trouble getting it to work.
    The device I am trying to flash is a STM8 microcontroller. I configured the IP address of the ATE and connected to it using telnet (using putty) and an FTP client. That all works as expected. I downloaded the Universal Flash Loader Configurator and loaded the hex file to flash. I have configured the configurator for the chip I have to program and configured the different bits (ERASE, PROGRAM, VERIFY, etc). I generated the UNI file, the DAT file, and clicked on Generate Test Data file... (which generated an MOT file). I loaded the files into the ATE module (only one for now) using FTP in the .MODULE1 folder. I'm not using serialization or patching. However, I cannot find where to generate the .cfg file or .pex file that the manual talks about on page 31. I did find STM8AS.pex that is referenced for my chip in the ST_STM8.xml in the UniversalFlashLoader folder. Is this the .pex file I need? How do I generate the .cfg file? I downloaded Flasher STM8, made a new project using the chip I have, set the same project settings as the universal loader configurator and hit "Save Programmer Configuration File..." which did produce a .cfg file.
    I put those on my ATE module 1 folder like such:
    /MODULE.001/STM8.CFG
    /MODULE.001/STM8.DAT
    /MODULE.001/STM8.HEX
    /MODULE.001/STM8.MOT
    /MODULE.001/STM8.UNI
    /MODULE.001/FLASHER.INI
    /MODULE.001/FLASHER.LOG
    /MODULE.001/STM8/STM8AS.pex
    Also, when I go to manually power on the board through either the USB or VTGT power, I get nothing on pin 19. I have tried #POWERON 1 0,0 and #POWERON 1 1,0. I have verified the USB and VTGT voltages are both right at 5V. I have tried setting the Vref to 5000 using #SETVTREF 1 5000. What am I doing wrong?
    Here are my current connections:
    Target ATE
    5V 19
    GND 4
    SWIM 9
    RESET 15
    TL;DR:
    I am having trouble setting up the flasher ATE using the universal flash configurator. I am also having issue with the #POWERON command not putting power to the board.
    Please can you help me?
    Jeremy
    • FLASHER.INI
      (58 Byte, downloaded 277 times, last: )
    • FLASHER.LOG
      (60 Byte, downloaded 276 times, last: )
  • I wanted to move past the POWERON issue for now and decided to just apply power to the board externally. When I did that I found out I had to have 5V also going to Pin 1 for target voltage reporting. After doing that I got this error from the log:
    ERROR: Cannot connect to CPU. Target interface speed too high?
    SN: 0 - Failed
    Changing HighSpeed = "0" did not fix it either.
    Here are my connections:
    5V -> Target Board Power In, ATE Pin 1, ATE VTGT + and Ext Power +
    GND -> Target Board GND, ATE Pin 4, ATE VTGT - and Ext Power -
    SWIM -> ATE Pin 9
    RESET -> ATE Pin 15
    These boards are pre-programmed and tested production boards.
    Any thoughts?
    Jeremy
    • FLASHER.LOG
      (372 Byte, downloaded 295 times, last: )
    We received your inquiry via support ticket as well.
    This thread will be closed now so no information gets lost between different communication channels.
