[SOLVED] Segger Linker 2.25
  • [SOLVED] Segger Linker 2.25
    I use a µC XMC4800, this controller flash has differnt address section for cached /uncached access
    PMU0 Program Flash Bank(non-cached) 2.0 Mbyte at 0C000000
    PMU0 Program Flash Bank(cached space) 2.0 Mbyte at 08000000
    ( different address space for the same physical memory, mapped in the non-
    cached address space )
    With the GNC linker i can set a VMA(virtual memory address) and a LMA(load memory address)
    For example:
    MEMORY
    FLASH_0_cached(RX) : ORIGIN = 0x08000000, LENGTH = 0x00010000
    FLASH_0_uncached(RX) : ORIGIN = 0x0C000000, LENGTH = 0x00010000
    .reset :
    KEEP(*(.reset));
    } > FLASH_0_cached AT > FLASH_0_uncached
    Is this also possible with the segger linker ?
    Embedded
    Virtual memory addresses are not supported by SEGGER Linker.
