[SOLVED] Xilinx single core (XC7007s/7014s) support in GDB
  • [SOLVED] Xilinx single core (XC7007s/7014s) support in GDB
    Dear,
    I noticed that for the EmUSB, there is support for the single core Xilinx Zynq devices (as also used on the Avnet Minized).
    We are using the single core (Z7014s), would it be possible to manually edit some files to make it possible to use the Segger GDB server on this device?
    We have it working on the Microzed, but we really would like to have it working on the single core variant also, that is used on our product.
    Kind regards,
    Tom Lamers
  • Hello Tom,
    The mentioned Xilinx core is currently not supported. A list with supported devices can be found here:
    You could try selecting the Z7010 instead and see if it works, but no promises.
    To quickly check if connection is working J-Link commander can be used.
  • Hello Tom,
