[SOLVED] Problems with GCC linker
  • [SOLVED] Problems with GCC linker
    I needed some new features of the C++ library and so I tried to get NewLib to work. After much effort, I was able to get it to work but I ran into some issues I don't understand.
    I turned off the ES standard library by selecting No for Project Options->Libraries->Include Standard Libraries. I also set Project Options->Libraries->Standard Libraries Directory to None.
    I put the NewLib library files on my machine at: C:/Depot/Source/Library/arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard
    So, I set Project Options->Linker->Additional Linker Options to:
    --verbose -LC:/Depot/Source/Library/arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard
    -lc
    Here is relevant portion of the output from the linker:
    1> Linking Blinky.elf
    1> "C:/Program Files/SEGGER/EmbeddedStudio/gcc/arm-none-eabi/bin/ld" -X --omagic -eReset_Handler --fatal-warnings --verbose -LC:/Depot/Source/Library/arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard -lc -EL --gc-sections -TC:/Depot/Source/32F401Disc/Blinky/Debug/Blinky.ld -Map Debug/Blinky.map --defsym=end=__heap_start__ -u_vectors -o Debug/Blinky.elf --emit-relocs --start-group @C:/Depot/Source/32F401Disc/Blinky/Debug/Blinky.ind --end-group
    1> GNU ld (GNU Binutils) 2.30.0.20180329
    1> Supported emulations:
    1> armelf
    1> opened script file C:/Depot/Source/32F401Disc/Blinky/Debug/Blinky.ld
    Then a little later:
    1> ==================================================
    1> attempt to open C:/Depot/Source/Library/arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard\libc.a succeeded
    This a little later:
    1> Debug/usbh_cdc.o: In function `USBH_CDC_InterfaceInit':
    1> C:\Depot\Source\32F401Disc\Blinky\Middlewares\ST\STM32_USB_Host_Library\Class\CDC\Src/usbh_cdc.c:170: undefined reference to `malloc'
    1> Debug/usbh_cdc.o: In function `USBH_CDC_InterfaceDeInit':
    1> C:\Depot\Source\32F401Disc\Blinky\Middlewares\ST\STM32_USB_Host_Library\Class\CDC\Src/usbh_cdc.c:296: undefined reference to `free'
    Build failed
    If I add libc.a to the project by adding the line below to the emProject file, I have no link issues.
    <file file_name="../../Library/arm-none-eabi/lib/thumb/v7e-m/fpv4-sp/hard/libc.a"> />
    Help, please. I cannot work out why the linker won't pick up libc.a when using Project Options->Linker->Additional Linker Options
    Harjit
    PS: I'm happy to post a detailed note on how to get NewLib to work with ES. I wish/beg you to update the library. I think you guys do a fine job overall but this area is seriously lagging.
    To make sure we understand you correctly, you want to use newlib. ES gives the error that malloc and free are not defined.
    Adding libc to the mix brings the missing functionality and everything is working correctly?
    This sounds like everything is working as expected to us, or are we missing something in your setup there?
  • When I use -L to tell the linker where to look and then -lc to use libc.a, the linker finds libc.a.
    When we use something from libc.a - example, malloc() and free(), they are not found / resolved with libc.a
    If I don't point the linker to libc.a using -L and then -lc but include libc.a as a file in the project, then the linker is able to resolve malloc() and free() to libc.a
    When adding external libraries to ES we recommend doing so via project options and not CL.
    To do so simply edit project option "Additional Input files".
