OS_Q_Create Documentation
  • OS_Q_Create Documentation
    I got a question regarding the documentation for OS_Q_Create (manual 3.82f).
    For the parameter pData it says: "Pointer to a memory area used as data buffer for the queue."
    But the example is as this:
    1. #define MEMORY_QSIZE 10000;
    2. static OS_Q _MemoryQ;
    3. static char _acMemQBuffer[MEMORY_QSIZE];
    4. void MEMORY_Init(void) {
    5. OS_Q_Create(&_MemoryQ, &_acMemQBuffer, sizeof(_acMemQBuffer));
    The '&' in front of '_acMemQBuffer' (line 5) puzzles me: that would be a pointer to a pointer to a memory area. Or am I wrong?
    Thanx, Arne
    An array name often (nearly always) evaluates (or 'decays') to a pointer to the first element of the array, but the array is not itself a pointer. Taking the address of the array (&_acMemQBuffer) also results in a pointer to the array (the pointer is of a different type, though), not a pointer to a pointer. Both expressions will be pointers with the same value, just somewhat different types.
    The expression _acMemQBuffer is a pointer with type char*.
    The expression &_acMemQBuffer is a pointer with type char(*)[10000] (ie., pointer to an array of 10000 char).
    Both pointers have the same 'numeric' value (they both point to the same address).
    Since the 2nd parameter of OS_Q_Create() is a void* there's no complaint about the pointer's type by the compiler (any pointer can convert implicitly to a void*).
    I think there's no error in the original example.
