JLinkSTR91x.exe Batch file command help
    • JLinkSTR91x.exe Batch file command help
      I wanted to know if it is possible to run the commands of the JLinkSTR91x.exe from a batch file. I thought it was going to be simple but I had no luck. I've been trying to set the boot bank to 1 just from creating a batch file that will open the executable and input setb 1. When I do it, it doesn't recognize that command from doing it through a batch file. Is there something I'm missing?
    • New
      To use a batch file with the J-LinkSTR91 Commander you can use CL options -CommanderScript or -CommandFile.
      How to use them is explained in the J-Link user guide UM08001 in section 3.2.3.
