[SOLVED] JLink/JMEM/MK66F18 - unable to read peripheral registers
  • [SOLVED] JLink/JMEM/MK66F18 - unable to read peripheral registers
    Using JMEM on an MK66FN2M0VM018 (FRDM-K66F) I am able to read Flash content (0x00000000), SRAM space (0x20000000, 0x1FFF0000) and Cortex-M space (0xE00000000). But on any attempt to read 0x40000000 space a ding rings and dashes shown.
    While it is understood unclocked peripherals can't be read this should not be the case for the SIM (0x40048000) or MCG (0x40064000).
    Workalot is wondering why.
    The AIPS registers starting at 0x40... have many gaps in between (See AIPS-Lite section in K66 manual). Trying to read the gaps will result in an error.
    If you execute mem32 0x40000000 1 in J-Link Commander you should be able to read the AIPS0_MPRA.
    JMem can't be used for reading memory with gaps as JMem will try to read the whole memory block you are currently looking at.
    On the K66 this will result in failure.
