[SOLVED] Bug report: Printf AND RTT prototype
  • [SOLVED] Bug report: Printf AND RTT prototype
    Printf over RTT has an improperly declared prototype and/or the function name is incorrect and/or comment is incorrect. This is with Release 4.10a Build 201810203.37618 Windows x64
    SEGGER_RTT.h has the following prototype:
    Source Code: SEGGER_RTT.h
    2. *
    3. * RTT printf functions (require SEGGER_RTT_printf.c)
    4. *
    5. **********************************************************************
    6. */
    7. int SEGGER_RTT_printf(unsigned BufferIndex, const char * sFormat, ...);
    I looked and there is no SEGGER_RTT_printf.c
    However, there is a SEGGER_RTT_SES.c and it has a printf() that looks about right.
    Source Code: SEGGER_RTT_SES.c
    1. int printf(const char *fmt,...) {
    2. char buffer[128];
    3. va_list args;
    4. va_start (args, fmt);
    5. int n = vsnprintf(buffer, sizeof(buffer), fmt, args);
    6. SEGGER_RTT_Write(0, buffer, n);
    7. va_end(args);
    8. return n;
    9. }
    I tested this printf, without a prototype, and it works just fine.
    The comment is correct. You can find the SEGGER_RTT_printf.c in the latest version either in your J-Link install folder under Samples\RTT
    or on the RTT website: segger.com/products/debug-prob…about-real-time-transfer/
    The SEGGER_RTT_SES.c should not be used here. That file defines the printf handling in case of RTT is used.
  • Sorry but I'm confused.
    When I used printf() in SEGGER_RTT_SES.c, I saw output in the Debug Terminal pane of Embedded Studio.
    It looks like SEGGER_RTT_printf.c in the Samples\RTT does the same thing.
    When should I use which one?
    What is wrong with using printf() in SEGGER_RTT_SES.c?
    Thanks.
    Thank you for the update.
