[SOLVED] ***** Error: Failed to prepare for programming. RAM check failed
  • [SOLVED] ***** Error: Failed to prepare for programming. RAM check failed
    I have a problem with the J-Link device. I'm debugging for a longert time with J-Link V4.80d on an Windows7 system with CLion without problems. Now for a new colleage I'm trying to set up a new system with a new J-Link on a windows 10 system. The settings in CLion are exactly the same, but for J-Link I have to use the new version 6.40. Now I have problems to flash my device (STM32F407IG). In The log file I have found the message "***** Error: Failed to prepare for programming.
    RAM check failed..." but I have no idea, what the problem is. I have attached the log file.
    Perhaps someone here can point me to the problem.
    • Jlink.log
      (183.35 kB, downloaded 262 times, last: )
    Could you verify general functionality using Ozone? segger.com/products/development-tools/ozone-j-link-debugger/
    Are you using an eval board or custom hardware?
    Is this issue happening with other projects as well or just this particular?
