EDIT widget - background transparency and cursor color
    • EDIT widget - background transparency and cursor color
      I have an EDIT widget in my user interface which I would like to have a transparent background. I thought this could be achieved with the following line, but it does not work. I also tried using "GUI_INVALID_COLOR" in place of "GUI_TRANSPARENT".
      EDIT_SetBkColor(hItem, EDIT_CI_ENABLED, GUI_TRANSPARENT);
      Is it the case that this widget simply does not support transparency? Other (opaque) colors seem to work just fine.
      Similarly, I am trying to set a custom color for the cursor line with the following, but the cursor always ends up being white.
      EDIT_SetTextColor(hItem, EDIT_CI_CURSOR, GUI_RED);
      I am able to manipulate other aspects of the widget just fine (text color, mode, cursor blink, etc.)
      emWin version 5.38
      per default the EDIT widget is not transparent. Try if it works when you set the transparent flag by calling WM_SetHastTrans(hEdit).
