[SOLVED] missing ";" compiler error points to wrong place, if preprocessor #define macro() is used directly after
  • [SOLVED] missing ";" compiler error points to wrong place, if preprocessor #define macro() is used directly after
    Hi, using SEGGER Embedded studio for ARM Release 3.40.
    Compiler error points to wrong place (headerfile).
    I had an error in my code but the compiler was pointing to a unrealated preprocessor macro in a headerfile.
    It is very confusing.
    Example code that isolates the problem
    // Macro without any error
    #define A_MACRO(ERR_CODE) \
    do \
    } while (0)
    // enum with missing ";" at the end
    enum missingsemicolon_e{
    MISSING_SEMI_COLON
    } // <<<----------- ERROR is here (missing ; )
    // call to macro just after.
    A_MACRO(err_code)
    Can somebody confirm this bug?
    Peter
  • Hello Peter,
    Yes the issue is reproducible with the example.
    Embedded Studio is using the ARM gcc and clang compiler so the issue comes from their error handling and not from Embedded Studio itself.
    GCC simply detects it wrong. If you use the same example and switch to clang in project options as compiler, you will get the correct error message:
    "expected ';' after enum"
    This thread will be closed now as this is issue is related to bugs in gcc and not Embedded Studio. For more information we suggest to get in contact with the gcc team at GNU-Projekt.
