[SOLVED] J-Flash Programming using batch file
  • [SOLVED] J-Flash Programming using batch file
    What I need the batch file to do is:
    1) Open J-Flash
    2) Open .jflash project
    3) Open .srec file
    4) F7 - Production programming
    5) F9 - Start Application
    My batch file as below:
    path C:\Program Files (x86)\SEGGER\JLink_V622a
    JFlash.exe -openprjC:\TI_LM3S9D90.jflash -openC:\v01.01.00.srec -auto -exit
    By using -auto, the batch file is able to do until F7 step, but it cannot do F9 (Start Application).
    May I know how to make batch file perform the F9 in J-Flash?
    Thanks & Best Regards,
    EK
    Normally -auto will execute all settings that you set in your J-Flash project under production, the same goes for the "Start Application" option under tab Production.
    How are your settings there? Could you post a screenshot or send us your jflash project for verification?
    The J-Link software version you are using is rather outdated. Could you try the latest one and report back if the issue persists?
