[ABANDONED] SES unable to open directory to read
  • [ABANDONED] SES unable to open directory to read
    Hello all,
    New to this page, and to SES and Nordic devices, but here goes,
    I have inherited a dev project based on the nrf51 series SOC. The app I inherited was developed using an early nrf51 SDK (v 11 I believe). I am hoping to port the app to SES using SDK 12.3. With Nordic help I can not compile and build, but the app does not run. During debug I get an error message that the it has reached an unknown function at an address. When trying to show the source code, SES cannot open the SES direcoty to read. The path length to the directory is considerably less than the 260 char Windows limit. The security for the path is wide open.
    Robin@TL
  • Hello Robin,
    Which ES version are you currently using?
    Could you provide a screenshot of the error message?
  • Nello Nino,
    I posted the window message in my original entry. Not sure where it went. Here it is again.
    Thanks for the support
    Robin
    The post was edited 1 time, last by robinsra818: Hello again Nino, I am now up and running under SES, but what I have noted is that randomly SES fails to build stating it cannot delete .asm files for source that is not in assembler code. It takes several attempts to get it to build, but once it does, it will build find until I make another minor change to the code. This seems to happen after a failed build due to a syntax error. Any clues what may be going on here? Thanks Robin ().
    Could you verify that this exact path is existing on your system, including possible typos?
    If not it might be a fragment of the porting process.
  • Hello again Nino,
    Here is the path copied directly from windows explorer:
    C:\NordicSDKs\nRF5_SDK_12.3.0_d7731ad\examples\ble_peripheral\ble_app_uart\pca10028\s130\ses
    No typos noted, please be a second set of eyes for me.
    Robin
