According the wiki page :
wiki.segger.com/I.MXRT1050#QSPI_flash :
Because with the standard qspi on the evk the qe bit is set but if we use another memory the qe bit is not set .
We need to write it manually after that all is working.
I sow that in IAR when changing the qspi model also the loade must change opening a project and adding the new memory.
Is NXP_iMXRT105x_QSPI source project available in a way that we can add our device and use the segger for the production withour add the qe bit manually ?.
Thanks and regards,
B.
- Open the JLinkDevices.xml (e.g. C:\Program Files (x86)\SEGGER\JLink_V631d\JLinkDevices.xml
- Search the desired iMXRT <Device> entry
- Change Loader="Devices/NXP/iMXRT105x/NXP_iMXRT105x_HyperFlash.elf" to Loader="Devices/NXP/iMXRT105x/NXP_iMXRT105x_QSPI.elf"
- Save the JLinkDevices.xml
Thanks and regards,
B.
