[SOLVED] J-Link and GCC with Eclipse
  • [SOLVED] J-Link and GCC with Eclipse
    Hi
    My Environment: Eclipse Luna C/C++, GCC 4.9 2015q3, SEGGER J-link ultra+ with v640 tools, NXP VF6xx_A5 processor
    Build process and debugging with j-link worked fine until I made an GCC update to GCC 5.4 2016q3.
    After the update the debugging with j-link doesn't work anymore. Build process still works. I tried also an update with GCC 7 2018q2 but the same not working debugging.
    The J-link JLinkGDBServerCL.exe runs. The Eclipse debug window shows 'one thread running' but when I suspend it there is written just nonsense. The code isn't really executing.
    no code changes, no cmake changes.
    Does anyone have an idea?
    Michael
    Which software are you using for debugging? Eclipse?
    Could you try Ozone instead with your eclipse output file?
