[SOLVED] Missing processor number during build
  • [SOLVED] Missing processor number during build
    Release 4.10a Build 2018110203.37618
    Windows x64
    Minor issue - during compilation, in the output pane, it used to show the core number being used for that command i.e. in the list below, at the start of the line instead of "1>" I would see "1>" or "2>" or "3>" or "4>" depending on which core was being used for the compilation/assembly. I no longer see that. Instead, I only see the "1>". Sample output is copied below. I deleted portions that had my path or extraneous stuff that didn't add value.
    Build->Parallel and Unity Builds->Building Threads is set to 8 and Disable Unity Build is not checked.
    I did run Task Manager and it shows all four cores with the same usage profile. So, presumably, all cores are being used.
    If I disable Parallel and Unity Build, it has no affect on the Task Manager core usage. Build->Parallel and Unity Build->Disable Unity Build checked.
    Sample output:
    1> Compiling ‘system_stm32f4xx.c’
    1> "C:/Program Files/SEGGER/EmbeddedStudio/gcc/arm-none-eabi/bin/cc1" <STUFF DELETED>
    1> In file included from Drivers/CMSIS/Device/ST/STM32F4xx/Include/stm32f4xx.h:171:0,
    1> from <STUFF DELETED>
    1> Drivers/CMSIS/Device/ST/STM32F4xx/Include/stm32f411xe.h:68:0: warning: "__FPU_PRESENT" redefined
    1> <command-line>:0:0: note: this is the location of the previous definition
    1> "C:/Program Files/SEGGER/EmbeddedStudio/gcc/arm-none-eabi/bin/as" <STUFF DELETED>
    1> rm <STUFF DELETED>
    1> Compiling ‘SEGGER_RTT.c’
    1> Compiling ‘SEGGER_RTT_SES.c’
    1> Assembling ‘thumb_crt0.s’
    -------------------->8-------------------8<--------------------
    Another item - please consider adding a feature to the Help->About dialog box to copy relevant version info. This way, we can click that and paste it into reports and you will have a common format for those that actually use it...
    Thanks!
    Harjit
  • Hello Harjit,
    Could you check your settings under Tool->Options->Building->Parallel Project Building
    This setting should be set to No.
