[SOLVED] J-Link mini - will not connect/unreliable connection with longer USB cable
  • [SOLVED] J-Link mini - will not connect/unreliable connection with longer USB cable
    I have been trying to use a j-link mini with a longer USB cable then the 4" cable that ships with the device. I have tried multiple (including brand new) 6' and 3' USB cables and have found that a lot of the time j-link software is unable to connect to the mini (when no board is attached to header), and when a board is attached (I tried multiple development boards from different vendors) it never is able to connect. Using the supplied 4" cable it connects and debugs the development boards fine every time. To isolate any ground loop/switching power supply noise issues I tried as well from a laptop that was running on battery power. Is there something I can do to get the mini to work with longer cables?
    Unfortunately there is no easy tip that will make any cables work as the cable quality even from the same cable vendor and same batch can have severe quality fluctuations in their signal quality.
    So we suggest to stick with the cable that is shipped with our devices as they are tested each before delivery. Any third party cables are not guaranteed to work.
