Please help me to get post mortem mode of systemview
    • Please help me to get post mortem mode of systemview
      Hi ,
      I am working on freertos and systemview in post mortem mode
      snapshot mode works fine and i had no issues with that.
      but when i tried post portem mode the events are not collected properly, the trace does not show the freertos task running.
      Perhaps i may be making mistake while reading the buffer.
      Please check the attached image.
      Buffer size = 8192
      wroff = 4972
      rdoff = 4971 ( so i understood that buffer is full )
      according to the user manual ,
      i am first reading from pbuffer+wroff to end of buffer in file 1; does that mean pubuffer+wroff to (8192-wroff) ??
      after that
      pBuffer until pBuffer + RdOff - 1 to another file 2
      now how to append file 1 and file 2 as said in the document .
      Please advice
      You can either append it by first reading both parts of the buffer, append it in your application and then export it to one joined file or use any e.g. hex editor to merge the two separate files.
