Dear Admin
I am stuck in this problem and cannot figure out what is the problem.
I am actually using STM32F446RE Nucleo board to flash an stm32f446me(/ze) controller using the SWD connector interface.
I have installed J-Link and when i execute this in terminal I get this output:
americium:~ umarahmad$ /Applications/SEGGER/JLink_V635g/JLinkExe
SEGGER J-Link Commander V6.35g (Compiled Oct 19 2018 17:36:50)
DLL version V6.35g, compiled Oct 19 2018 17:36:40
Firmware: J-Link STLink V21 compiled Jun 26 2017 10:35:16
Hardware version: V1.00
S/N: 773535799
VTref=3.300V
Now afterward when I try to connect with my device and use the connect command, i get this
J-Link> device stm32f446ze
J-Link>connect
Please specify target interface:
J) JTAG (Default)
S) SWD
T) cJTAG
TIF> S
Specify target interface speed [kHz]. <Default>: 4000 kHz
Speed>
Device "STM32F446ZE" selected.
Connecting to target via SWD
STM32 (connect): Can not attach to CPU. Trying connect under reset.
****** Error: STM32: Connecting to CPU via connect under reset failed.
Cannot connect to target.
I have also tried using the /Applications/SEGGER/JLink_V634h/JLinkSTM32Exe utility and this is what i get from that:
americium:~ umarahmad$ /Applications/SEGGER/JLink_V634h/JLinkSTM32Exe
SEGGER J-Link Unlock tool for STM32 devices
Compiled Oct9 2018 15:49:24
(c) 2009-2015 SEGGER Microcontroller GmbH, segger.com
Solutions for real time microcontroller applications
This program is designed to reset the option bytes of a STM32 device to their factory settings. If read protection of the device is enabled, reset the option bytes will cause a mass erase.
Options:
[0] Exit
[1] STM32F0xxxx
[2] STM32F1xxxx
[3] STM32F2xxxx
[4] STM32F3xxxx
[5] STM32F4xxxx
[6] STM32F72xxx, STM32F73xxx
[7] STM32F74xxx, STM32F75xxx
[8] STM32F76xxx, STM32F77xxx
[9] STM32L0xxxx
[10] STM32L1xxxx
[11] STM32L4x6xx
Please select the correct device family: 5
Using SWD as target interface.
Target interface speed: 1000 kHz.
VTarget = 3.300V
Reset target...O.K.
Reset option bytes (may take app. 20 seconds)...Memory read failed.
Unlock not successful.
Press any key to exit.
please help
I also tried using the Jlink, please see attachments
S/N: 773535799
VTref=3.300V
J-Link>connect
J) JTAG (Default)
S) SWD
T) cJTAG
TIF> S
Speed>
Options:
[0] Exit
[1] STM32F0xxxx
[2] STM32F1xxxx
[3] STM32F2xxxx
[4] STM32F3xxxx
[5] STM32F4xxxx
[9] STM32L0xxxx
[10] STM32L1xxxx
[11] STM32L4x6xx
VTarget = 3.300V
Reset target...O.K.
please help
